h_tsopelas
Aug 03, 2015Aspirant
How to backup from remote to local
Hello again... i want to back up my main folder with my files from Remote to a folder which i have create to the local. I try to do this but when i select remote it wants to fill: Host Protocol S...
- Aug 04, 2015
It ok now... my fault was that i do not share the folder which i want to take the backup. I do it with the first protocol!
h_tsopelas
Aug 04, 2015Aspirant
I remove the "/" in the share name, nothing... I enable the Rsync on the NAS system, nothing. I do not set up Rsync on my linux computer and maybe this is the problem.
Could you help me how to set up the Rsync to the linux?
I try NFS and windows Timestamp protocol and i take "Unable to connect to remote folder: invalid network name or permission denied."
From windows, how i can find the host? I have a second pc with windows 8 inside.
h_tsopelas
