InteXX's avatar
InteXX
Luminary
Sep 10, 2015
How to backup from remote to local
I'm preparing a script to perform a nightly backup of files from my Windows server to my RN104. After each copy action is complete I'd like the script to compare the checksums for the file as it exis...
  • InteXX's avatar
    InteXX
    Sep 12, 2015
    OK, got it. Here's how:
    1. Browse to the ReadyNAS Admin Page
    2. Go to System\Settings and enable SSH
    3. Download and install PuTTY from here: http://www.putty.org/
    4. Add the PuTTY installation folder to your system path (optional)
    5. Create a simple PowerShell script with this code, modifying the file location where necessary:
      $CheckSum = (plink -pw password root@readynas md5sum /data/ShareName/Folder/File.txt) | Out-String
      $CheckSum
    6. Run the script
    7. Note that the md5 command result is captured to the local variable and then output to the local console
    8. You may process this result using standard PowerShell commands as desired
    Note that direct support for SSH in PowerShell is coming soon:
    http://blogs.msdn.com/b/powershell/archive/2015/06/03/looking-forward-microsoft-support-for-secure-shell-ssh.aspx
    HTH
    Thanks,
    Jeff Bowman
    Fairbanks, Alaska
ProSupport for Business
