InteXX
Sep 10, 2015Luminary
How to backup from remote to local
I'm preparing a script to perform a nightly backup of files from my Windows server to my RN104. After each copy action is complete I'd like the script to compare the checksums for the file as it exis...
- Sep 12, 2015
OK, got it. Here's how:
- Browse to the ReadyNAS Admin Page
- Go to System\Settings and enable SSH
- Download and install PuTTY from here: http://www.putty.org/
- Add the PuTTY installation folder to your system path (optional)
- Create a simple PowerShell script with this code, modifying the file location where necessary:
$CheckSum = (plink -pw password root@readynas md5sum /data/ShareName/Folder/File.txt) | Out-String $CheckSum
- Run the script
- Note that the md5 command result is captured to the local variable and then output to the local console
- You may process this result using standard PowerShell commands as desired
Note that direct support for SSH in PowerShell is coming soon:
HTH
Thanks,
Jeff Bowman
Fairbanks, Alaska
Sep 11, 2015Guru - Experienced User
You'd need to install something on the NAS to compute the checksum and return it to you.
You can get the same effect by using Microsoft's FCIV freeware ( https://support.microsoft.com/en-us/kb/841290#bookmark-4). It has a CLI interface and can checksum a file using a network path (e.g., FCIV \\nasname\sharename\filename works). So you can checksum the source and destination from your script on the server, and compare the two.
FCIV would be a bit slower, since it is reading the file over the network to compute the checksum. But it would be simpler to implement.
InteXX
Sep 12, 2015Luminary
- Run the script
HTH
Thanks,
Jeff Bowman
Fairbanks, Alaska
