rymiller
Aug 07, 2018Aspirant
How to backup hidden home directory on Duo V2
Since the replication service is going away we all need to figure out how to backup. My problem is backing up a Duo V2 on Radiator 5 to an OS6 NAS. Today with ReadyNas Replicate it works great. Th...
mdgm-ntgr
Aug 07, 2018NETGEAR Employee Retired
You could try using SMB as the source using the admin credentials and put homes (or home, I forget which) in the path field (it'll be the same as what shows when you login to the NAS from your PC via SMB).
The Duo v2 is an old NAS. It may be advisable to get a second OS6 NAS Storage device and using that going forward.
Aug 08, 2018Guru - Experienced User
You might also consider if you really need the home shares. You could replace them with ordinary shares (with appropriate access controls).
Note that you wouldn't be able to match the share names with the user account though (the NAS won't allow you do to do that).
