dahouet's avatar
dahouet
How to change home directories volume ?
Hello
It seems that ReadyNas use the first volume created to host home directories.
I search how to change the volume on the internet
I found that i have to change in /lib/systemd/system/home.mount
[Mount]
What=/SECURED_DATA/home
It seems to work after reboot. Files are now hosted on the new volume however
In the GUI, it still appears on the old volume.
In the db, i found the table "account_default" which to contains the information.
I changed it and it worked but only during current runtime !
After reboot, the "home folders" are back on the old volume in the gui
How to change it forever ?
Thanks for your help.
Regards
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Perhaps you also need to change it in /etc/frontview/account.conf
  • Thanks.
    Sorry i did not receive emails update for this thread.
    However, seems to work !
    Thanks
ProSupport for Business
