Boonpflug
Aug 19, 2019Aspirant
How to change the path for "Sync with PC"?
Hi, so I think my use-case should be rather common, but I have not yet found the info I need. I have a home computer with a RN104 and the PC has windows 10 installed on an SSD (low storage volume...
- Aug 20, 2019
Boonpflug wrote:
The "backup" feature seems to create files as long as there is space on the NAS, but this clutters the NAS which is also used by my partner.Also i sometimes create manual backups of the most critical backups (e.g. via robocopy), and those un-deleted files prevent this.
I don't understand what you mean by the "backup feature". Snapshots aren't the same as backup. RAID isn't enough to keep your data safe; you do need a backup on a different device for that (as you are doing with Robocopy).
Boonpflug wrote:
I want to sync them. e.g. if i delete a file on the PC it is deleted on the NAS.
It sounds like you want two-way sync. This of course does make your data more vulnerable (increasing the attack surface to include both the NAS and the PC). For instance, if ransomware hits the PC, you'll lose the files on the NAS too.
This is a desktop PC? If so, then you don't need to worry about sync working over the internet.
I believe FreeFileSync will do what you want (it has a real-time sync capability).
Aug 19, 2019Guru - Experienced User
Boonpflug wrote:
but there seems to be no way to customize the path?
Correct. You'll need to use a different sync tool.
Boonpflug
I see, any recommendation?
- StephenBAug 20, 2019Guru - Experienced User
Is your purpose to back up the NAS onto the PC?
Or are you wanting to accomplish something else?
- BoonpflugAug 20, 2019Aspirant
I want to sync them. e.g. if i delete a file on the PC it is deleted on the NAS. The sync feature seems perfect for my purpose. The "backup" feature seems to create files as long as there is space on the NAS, but this clutters the NAS which is also used by my partner. Also i sometimes create manual backups of the most critical backups (e.g. via robocopy), and those un-deleted files prevent this.
