gyves1
Mar 16, 2017Luminary
How to clean up the system volume "root" without factory reset to improve the ReadyNas performances?
One of moderators said me that my "root" is too full. How can I clean up the system volume "root" without factory reset to improve the ReadyNas performances ? Is there an application or add-o...
mdgm-ntgr
Mar 16, 2017NETGEAR Employee Retired
You'd need to SSH in as the 'root' (no quotes) user and have a log around e.g.
# mount --bind / /mnt # du -csh /mnt/*
- gyves1Mar 16, 2017Luminary
Here the log:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.03.16 23:02:19 =~=~=~=~=~=~=~=~=~=~=~=
login as: root
root@homedisk's password:Welcome to ReadyNASOS 6.6.1
Last login: Thu Mar 16 22:35:28 2017 from fe80::dde2:6310:93e8:f9f0%bond0
root@homedisk:~# mount --bind / /mnt
root@homedisk:~# du -csh /mnt/*
0/mnt/apps
7.4M/mnt/bin
0/mnt/boot
0/mnt/config
8.0K/mnt/cp_check_md5sums.sh
0/mnt/data
24K/mnt/dev
0/mnt/Downloads
13M/mnt/etc
0/mnt/evs_temp
29M/mnt/frontview
0/mnt/home
0/mnt/Incomplete
34M/mnt/lib
3.6M/mnt/lib32
4.0K/mnt/lib64
28K/mnt/media
0/mnt/mnt
5.8M/mnt/opt
0/mnt/proc
0/mnt/+ÌR
32K/mnt/root
0/mnt/run
11M/mnt/sbin
0/mnt/selinux
0/mnt/srv
0/mnt/sys
18M/mnt/tempdata
4.0K/mnt/test_crontab.txt
4.0K/mnt/tmp
702M/mnt/usr
359M/mnt/var
1.2Gtotal
