gyves1
Mar 16, 2017Luminary
How to clean up the system volume "root" without factory reset to improve the ReadyNas performances?
One of moderators said me that my "root" is too full. How can I clean up the system volume "root" without factory reset to improve the ReadyNas performances ? Is there an application or add-o...
jak0lantash
Mar 16, 2017Mentor
gyves1 wrote:Is there an application or add-on on Netgear ReadyNas market place to download and could help to clean up the system like the CCcleaner app from Piriform?
You'll have to do things manually from SSH.
Please send the output of the following commands:
mount --bind / /mnt du -d1 -h /mnt/
gyves1
Here the second result
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.03.16 23:13:16 =~=~=~=~=~=~=~=~=~=~=~=
login as: root
root@homedisk's password:
Welcome to ReadyNASOS 6.6.1
Last login: Thu Mar 16 22:35:28 2017 from fe80::dde2:6310:93e8:f9f0%bond0
root@homedisk:~# mount --bind / /mnt
root@homedisk:~# du -d1 -h /mnt/
7.4M/mnt/bin
0/mnt/boot
24K/mnt/dev
13M/mnt/etc
0/mnt/home
34M/mnt/lib
4.0K/mnt/lib64
28K/mnt/media
0/mnt/mnt
5.8M/mnt/opt
0/mnt/proc
32K/mnt/root
0/mnt/run
11M/mnt/sbin
0/mnt/selinux
0/mnt/srv
0/mnt/sys
4.0K/mnt/tmp
702M/mnt/usr
357M/mnt/var
0/mnt/data
0/mnt/apps
18M/mnt/tempdata
112K/mnt/.conf
0/mnt/.work
16K/mnt/.log
0/mnt/.events
3.6M/mnt/lib32
0/mnt/config
0/mnt/Downloads
0/mnt/Incomplete
24M/mnt/.dropbox
0/mnt/evs_temp
29M/mnt/frontview
1.2G/mnt/
root@homedisk:~#
login as: root
7.4M/mnt/bin
0/mnt/boot
24K/mnt/dev
13M/mnt/etc
0/mnt/home
34M/mnt/lib
4.0K/mnt/lib64
28K/mnt/media
0/mnt/mnt
5.8M/mnt/opt
0/mnt/proc
32K/mnt/root
0/mnt/run
11M/mnt/sbin
0/mnt/selinux
0/mnt/srv
0/mnt/sys
4.0K/mnt/tmp
702M/mnt/usr
357M/mnt/var
0/mnt/data
0/mnt/apps
18M/mnt/tempdata
112K/mnt/.conf
0/mnt/.work
16K/mnt/.log
0/mnt/.events
3.6M/mnt/lib32
0/mnt/config
0/mnt/Downloads
0/mnt/Incomplete
24M/mnt/.dropbox
0/mnt/evs_temp
29M/mnt/frontview
1.2G/mnt/
root@homedisk:~#
