BogilyG
Nov 24, 2009Follower
How to configure Duo as Non-RAID
I have a ReadyNAS Duo which came with a single 1 TB drive. I want to upgrade it to 2 TB. The forum FAQ has the following question and answer: » Does ReadyNAS support JBOD or some sort of non-RAID s...
tedebus
May 07, 2012Aspirant
dbott67 wrote:
You will need to factory default your Duo and switch to Flex-RAID 0 mode. This will allow you to use each disk independently with a separate volume on each disk. Switching RAID modes requires a factory default, meaning that all data and settings will be lost. You would need to backup your data and restore.
I don't think so... Flex-RAID 0 mode creates a single bigger logic volume, data would be spanned on both hard disks. That's a standard RAID functionality.
If you need two logical volumes you must select JBOD mode instead.
I know... this is an old topic, but this information may be important.
