BogilyG
Nov 24, 2009Follower
How to configure Duo as Non-RAID
I have a ReadyNAS Duo which came with a single 1 TB drive. I want to upgrade it to 2 TB. The forum FAQ has the following question and answer: » Does ReadyNAS support JBOD or some sort of non-RAID s...
mdgm-ntgr
May 08, 2012NETGEAR Employee Retired
On the v1 you can delete the volume automatically created and create one RAID-0 volume per disk to effectively do JBOD.
On the v2 when you choose Flex-RAID in RAIDar you can choose the JBOD option for the RAID level.
