nglshmn
Nov 30, 2017Tutor
How to force expansion in RAID-X after disk addition?
I have an RN31400 using X-RAID and the latest firmware (6.9.1). I had 4 disks, 8T8, 8Tb, 6Tb & 6Tb. I replaced the third disk with an 8Tb one, meaning I now have 8Tb, 8TB, 8Tb & 6Tb. All are WD ...
nglshmn
Nov 30, 2017Tutor
Sorry, 15.5Tb, not 14Tb of available space.
- SandsharkNov 30, 2017Sensei
Did you start with all 6TB's? It sounds like it's only using 6TB on all of your drives. Is XRAID enabled? That would be the case for Flex-RAID.
Do ou have SSH enabled and can you go in and execute lsblk? That will show you what partitions on what drives are included in your volumes. Post results here if you need help interpreting them.
- nglshmnNov 30, 2017Tutor
No, the two 8’s and the two 6’s. They weren’t XRAID, so converted to that first. That’s obviously where the problem occurred. Th question is, apart from a fresh reset again, can I force it to do XRAID properly?
I think I can SSH in, but what will that show me? Can I then use a command to fix it?
Thanks.
- StephenBDec 01, 2017Guru - Experienced User
You should have had a 20 TB (~18 TiB) volume before you upgraded the disk.
Do you recall what RAID mode you were running before you switched to XRAID?
