makkistyle
Oct 03, 2024Tutor
how to format HDD and wipe all data
Hi, I would like to Wipe my HDD and Format all the data and reusing it again the format button is inactive but the DESTROY is active if I choose destroy then what next step will I be abl...
- Oct 05, 2024
makkistyle wrote:
but will my MAC will recognize and will show on list ?
I don't own a Mac, but I think it will
makkistyle wrote:
after this I can return the HDD to the NAS Server and it will work fine
or it will requires to do some settings
The secure erase done in the Mac will return the disks to an unformatted state.
Putting them back in the NAS will work fine. When you power up with the first one installed, the NAS will do a fresh factory install. Switch to flex-raid, and hot-insert the second disk. You can either set up RAID-0 or two JBOD volumes.
IMO, two JBOD volumes is better. With RAID-0 you lose everything in the volume when either disk fails. With JBOD you only lose what is on the failed disk.
makkistyle
Oct 03, 2024Tutor
I want to wipe both HDD and reuse it again as Raid 0
in same NAS
but would be different if I'm going to transfer the HDD to another NAS ?
I have one app installed (Plex)
Oct 03, 2024Guru - Experienced User
Then begin by uninstalling it. It uses a hidden folder on the data volume, so it will need to be reinstalled after you create a new volume.
After that, use "destroy". You can then format them from the web ui, and create a new volume.
Once that is done, you need to recreate the shares, reinstall plex, and restore your files from a backup.
"Destroy" would still be the place to start. If you are moving to another manufacturer's NAS, you'd need to format it in their system. ReadyNAS systems include a small OS partition and a swap partition that are not part of the data volume. You'd need to remove those also, and the process above doesn't do that.
FWIW, if you were selling the hard drives, I'd suggest zeroing them before sale.
- makkistyleOct 03, 2024Tutor
ok to be strait forward
I'm planning to sell the NAS but with formatted HDD but in same time leaving the HDD ready for the buyer
so he can decide wither to setup it the way he want or move the HDD to another NAS
so what you suggest
- StephenBOct 03, 2024Guru - Experienced User
What model are the disks?
IronWolf NAS
