Retired_Member
Feb 25, 2014How to get into flex-raid?
I just got the the ReadyNAS 314 and I can't figure out for the life of me how to get into Flex-Raid. I've ready the manual and documentation online.. I reboot the system and go to Factory Default. The...
Retired_Member
Feb 26, 2014I understand the drawbacks of RAID-0. However, I use CrashPlan... so if a hard drive were to fail, I simply just do a restore after replacing the broken hard drive.
With the ReadyNAS 314 only having 4 bays, I need to utilize my hard drives to gain the maximum amount of disk space available.
I just got the ReadyNAS setup and I'm restoring all my files now as I type this from CrashPlan :-) 4.6TB of data will only take 6-8 days to restore according to the CrashPlan software (I have a 115Mbps Internet connection).
