Dewdman42
Apr 15, 2016Virtuoso
how to get rid of Mysql systemctl
At some point I installed the MySQL addon and removed it later when I decided to use postgres. However, MySQL is still left running on my system and enabled as a systemctl service, even after reboot...
Dewdman42
Yes I tried to use systemctl disable on everything mentioned. They came back on boot. No I don't have any cloud services enabled. I may have TRIED to enable ReadyCloud once, but it didn't work and I turned it off in front view.
what I can say is that numerous addons leave Sh__T hanging around..that's all i can say. I'm going to do a factory reset and be careful not to install anything I don't want to get stuck with, like mysql, readycloud, rsyslog, etc.
siigna
Apr 15, 2016NETGEAR Employee Retired
I edited my reply above. systemd will translate init.d service so you can start and stop them, but enable and disable won't work. Need to use update-rc.d. I suspect the leafp2p issue is the same.
