PasadenaDave
Oct 21, 2011Aspirant
How to login using SSH, Telnet, Putty ?
How do I login to my NAS using Putty? It should be supporting the SSH protocol? If it needs the ssh protocol added, how does it get executed without having it to start with....?
Thx ??
Thx ??
- ewokNETGEAR ExpertInstall the EnableRootSSH addon from readynas.com.
- PasadenaDaveAspirantHave the file there, how do I log in to execute it???
FTP gives no execute permissions..... - mdgm-ntgrNETGEAR Employee RetiredIt's installed via Frontview (web-admin interface of the ReadyNAS)
Go to System > Update > Local - PasadenaDaveAspirantThank you... That was the key. Wonder why the admin "ewok" didn't say it???
Up and running. Thanks so much !! :D - klomAspiranthello,
the only thing i want to do is hosting a website from my readynas. i have istalled apt, The EnableRootSSH addon, and then i have to go to the root to typ this:
# apt-get update
# apt-get install libapache2-mod-php5
but how do i get to the root???????
if i need to install putty, can somebody please expleen how to do this?
thanks,
klom - klomAspirantbefore anyone starts to answer, i think i found it :D :D :D
- what device do you have?
you should be very careful about installing and upgrading apt packages, some of them can cause problems with the customised built-in packages. - klomAspiranti am trying to install cms made simple to my server.
now i am so far that i have the installsite, but the installed php5 is to old to make it work.
how do i upgrate my readynas to a higher php5. to php5.3.8??
it should be very easy to install cms made simple but it won't work..... :hammer:
