uplink
Jun 04, 2013Aspirant
How to map a network drive using ReadyNAS OS 6.x.x
Greetings, I'm very sorry for my lame question. I even searched Your forums for the answer, but most of You guys use the ReadyNAS Duo system, not the one I have. Also, I read the users manual, spen...
Jun 04, 2013Guru - Experienced User
If you enter 192.168.1.235\admin\data\public, explorer opens Internet Explorer, and you get the URL message from IE. Just entering the IP address does the same.
Etz wrote:
uplink wrote:
Not Found
The requested URL /admin/data/public was not found on this server.
This makes me wonder, are you trying to access it with Internet Explorer or Web browser?
As posted, the correct syntax is \\192.168.1.235\public
Or just enter \\192.168.1.235, and then navigate to the share you want.
