zeke561
Jan 06, 2020Guide
How to modify samba config with raidiator 4.2.31
I have a need, if possible, to enable SMB2 on an ultra 4 plus running raidiator 4.2.31. I have read that it is possible with this version of OS to edit /etc/samba/smb.conf to include specifications ...
Jan 07, 2020Guru - Experienced User
zeke561 wrote:
Can you point me to those files?
You can find the bios download here: http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin
zeke561 wrote:
I agree that upgrading to OS6 would be the optimal solution. For a few reasons it is not a viable option at this time. Running SMB2 is my desired workaround.
You could try this: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Enable-SMB-2-on-ReadyNas-x86-v4-2-31/m-p/1455830#M139865
But I'm not sure if the setting will be sticky or not.
zeke561
Jan 14, 2020Guide
It looks like I missed this reply, so belated thanks. Anyway, the procedure outlined in the link, editing /etc/samba/smb.conf is what I tried and does not work. I would try to edit the one in the default directory (/etc/default/config/etc/samba) but I don't want to cause problems I can't easily solve, since SMB isn't my highest priority for this machine and I can work around it.
