dougusc's avatar
dougusc
How to recover data from Readynas NV+ with failed power supply
I have an old ReadyNAS NV+ RND4210 and the power supply went out.  I have lots of data backed up in a RAID configuration.  I am looking for recommendations for how I can recover the data from the drives.  I had 4x2GB drives.
I guess I see two options:
1. Buy a new power supply.  But, this is not straight forward.  Lots of power supplies out there and can't find an exact match.  And also > $100.
2.  Buy a new NAS.  But, will it take my current drives?  Can I recover the data without paying Netgear feeds to do the work?
Any help would be appreciated.  Thanks,
  • dougusc wrote:
    I did not do that connector modification.  I would like to try that.  Is there a connector that I could purchase to make those changes?  Or do I need to cut wires and rewire them?
    You can rewire the PSU ATX cable.  Or you can purchase an inexpensive ATX extension cable, and make the wiring change there.  Personally I'd go with the extension cable (so you wouldn't need to reverse the mod to the PSU later on).  But both will work.
  • StephenB's avatar
    Paid support can mount the disks temporarily in a new ReadyNAS so you can offload the data.  I don't know what that would cost.  More information on that is here: https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
    dougusc wrote:
    Can I recover the data without paying Netgear fees to do the work?
    Note a variation on option (1) is to use an external ATX supply temporarily.  That would be less expensive (or even free if you have an old PC you can pull the supply out of).  There is a small modification needed to the PSU connector.  However, you can do that in an extender cable, leaving the PSU intact.
    Option 3 would be to mount the disks in a linux PC (most PCs can be booted up under linux).  If your PC doesn't have enough SATA ports, you'd need a USB enclosure of some kind - cost would be similar (or perhaps more) than a replacement PSU.
    A variant here is to purchase R-Studio for Windows (and avoid linux).  R-Studio normally would cost about $80, at the moment you could get it for $60.
    • dougusc's avatar
      dougusc
      Hi StephanB,
      Thanks for the quick reply.  I had an old ATX PS and tried that.  The connector hooked up, but the NAS would not start.  I am thinking that it might be a different issue than the PS.
      I also installed Linux and was able to connect one of the NAS 2TB drives.  But, I can't get access to see any of the files.  Maybe there is some trick to get access and mount the drives that come out of the NAS.  I get this error in Linux:
        "Unable to access location.  Error mounting...."
      I will do more research on mounting one of the NAS drives.
      Thanks,
      • dougusc's avatar
        dougusc
        One other question....
        Is there another Netgear product that I could purchase where I might be able to install my 4x2TB drives to recover the data?  I probably was in need of an upgrade anyway.  I would hate to have to buy another ReadyNAS NV+ or pay for recovery services.
        Thanks,
ProSupport for Business
