bolder1
Feb 20, 2014Aspirant
How to Reformat Disks in ReadyNAS Ultra 2
So here I am stuck again at the beginning. I've got the Ultra2 set up in RAID. But I realize that I don't need redundancy. I just need a large file server that can serve video files. Since RAID isn't ...
vandermerwe
Feb 20, 2014Master
The NAS will use ext4.
It isn't clear from your post whether you're using xraid or flexraid at the moment.
If your using xraid then you'll need to factory default ( can be done in Frontview), then you will have a 10 minute window during which you need to use Raidar ( the PC utility) to discover the NAS and select flexraid.
Once you have done this you can manipulate your volumes as you wish and it should be easy to set up 2 volumes as you propose.
I think the reset description you are referring to is the boot menu method for doing a factory default.
