bolder1
Feb 20, 2014Aspirant
How to Reformat Disks in ReadyNAS Ultra 2
So here I am stuck again at the beginning. I've got the Ultra2 set up in RAID. But I realize that I don't need redundancy. I just need a large file server that can serve video files. Since RAID isn't ...
bolder1
This is maddening. So everything went as planned - thanks. Logged into FrontView and you have to go to Volume Settings. There is no option to format the drives in anything other than RAID 0 or 1. There is no option to get two drives formatted as EXT3 or EXT4. I'm using RAIDiator 4.2.26 so I've got the latest update but it's just not there. I look in the manual and I don't see it either. Hmmmm.... I'd really like to avoid having to use RAID-0 as one big 7.38TB hard drive and would prefer to have the dual drives. It makes replacing the data so much easier than need to restore twice the data in case one fails!
