bolder1's avatar
bolder1
How to Reformat Disks in ReadyNAS Ultra 2
So here I am stuck again at the beginning. I've got the Ultra2 set up in RAID. But I realize that I don't need redundancy. I just need a large file server that can serve video files. Since RAID isn't backup, the backup will take place offline and I think I can set up the Ultra2 as two EXT4 volumes. This will give me optimally an 8TB media server, which is pretty nice. But how do we do this? I believe that the disk must be reformatted as EXT4 as there is no conversion that can be done as with RAID and FLEX. I am thinking of EXT4 because I think that if the ReadyNAS failes, a RAID or FLEX-RAID formatted disk cannot be read by anything other than the ReadyNAS.
Now here comes the real problem.... this seems like a ridiculous question but my first run through setting up the Ultra2 was ghastly. I couldn't find any manual that provided me with the setup procedure that worked. I had to find some doc written by someone on a website on how to configure the Ultra2 using some specialized button settings to put the ReadyNAS into a reset mode, etc. Compared to my Synology, this was a real shocking nightmare. Is there anyone who can point me to the beginning to end processing of setting up the ReadyNAS that actually works? I realize that RaidAR and the software to login will not allow me to reformat directly, as appears the case with the Synology. It requires something be done on the Ultra2.
Thank you all for your help and your patience for my question!
  • Wow... thanks.... you are a total lifesaver!
    Yes... it does work but the choice for "add volume" is inconspicuous and so easy to miss.
    I think I'm incredibly frustrated because compared to the Synology NAS I just bought, using this Ultra 2 that I bought just 8 months ago is like using Windows 95 vs WIndows 7. After buying the ReadyNAS I was surprised to find the add-ons section neglected for years. Reading this forum it's as though help is provided through the goodwill of people like yourself, to whom I'm grateful. It looks like it is finally set up as C and D, non-proprietary format. Again.... many thanks. Sorry about the frustration! 8)
  • Glad it's working.
    A few things:
    1. If you aren't already running RAIDiator 4.2.26, upgrade by clicking System:Update. This is particularly important if you're running firmware earlier than 4.2.24.
    2. After upgrading the firmware, make sure you have the latest BIOS. Download this addon:
    http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin
    and install it by clicking Add-ons:Add New. Click Browse and find the downloaded addon file, then click Upload And Verify Image. If your BIOS is already up-to-date, this will do no harm. Note that although the BIOS-upgrader installs like an addon, it isn't actually an interactive addon: It won't appear in the list of installed addons, and there's nothing to remove after you install it.
    3. It might be a good idea to install the Enable Root SSH addon, just in case you need to get access to the NAS's Linux command line sometime. Download the addon from here: http://www.readynas.com/?p=4203 (choose "x86") and install it the same way you installed the BIOS addon. Like that one, this "addon" isn't really an add-on; it won't appear in the list of installed addons, and there's nothing to remove after it's installed. The warning on the download page about Netgear denying support probably isn't anything to worry about; all it really means is that since they can't possibly support all the crazy things people might do once they have complete access to the NAS's Linux internals, they won't necessarily help you fix anything that you break by using the command line. Simply installing the addon does not void your warranty.
    4. It's true that many of the addons that have been created are no longer maintained, but many are still kept up to date, and even the old ones often work just fine. See https://rnxtras.com/addons/category/readynas-os4-x86 for the addons created and maintained by WhoCares. If you see other addons that interest you (even "official" addons from Netgear), ask here on the forum before installing them, just to make sure that you're not about to install one of the old addons that actually doesn't work very well. In particular, it's better to install the PHP addon from WhoCares than the much older, unmaintained PHP addon from Super-Poussin. Many of the other Super-Poussin addons work great -- I'm using a number of them -- but he's now concentrating on addons for OS6, so his OS4 addons are all unmaintained, as far as I can tell. Slobberbone also has a few useful addons, but his web page seems to be down at the moment. Maybe it'll be up again soon: http://www.slobberbone.net/dotclear/index.php?pages/ReadyNAS-Addon
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    You can run ReadyNAS OS 6 on the Ultra 2 if you want a more modern web-admin interface, but upgrading to that requires a factory default (wipes all data, settings, everything).
  • mdgm - I was under the impression that ReadyNAS OS 6 isn't supported on the Ultra 2.
    http://kb.netgear.com/app/answers/detail/a_id/20684/~/readynas-downloads
  • mdgm - Thanks for the reference. I'll take a look through the thread and see what the limitations are and the potential benefits. I truly appreciate you pointing me to this option which Netgear apparently isn't offering or supporting officially. Hard to believe but it is what it is and with many thanks to you guys.
ProSupport for Business
