joel80
Dec 02, 2015Tutor
how to remove a hard disk clean from a raid (RN 314, using SSH)
Hey there, i would like to remove a specific hard drive from the volume cleanly. First, is my plan very risky, even possible at all in this way? Afaik i would first use: btrfs device ...
Dec 05, 2015Guru - Experienced User
You need to be very careful on what you google here.
btrfs has some built-in raid-like features that OS6 doesn't use. OS6 builds the RAID array using mdadm, and then creates btrfs on top of that. The ReadyNAS software also needs to stay in sync with the current raid configuration (and I think the info is also kept in its SQL database).
There might be a way to do all the needed steps manually, but Netgear certainly hasn't documented it, and sorting it out on your own would be very high risk.
joel80
Dec 05, 2015Tutor
thank you. I didn't know thew that. Thats the reason why iam asking here, before doing anything ;-)
- StephenBDec 05, 2015Guru - Experienced User
A couple of folks have asked for the ability to shrink an array. It'd be a lot of work for Netgear, but there are times when it would be useful.
- Equinox1Dec 06, 2015Guide
I agree; shrinking an array is very useful at times, especially when you have a fully populated NAS.
StephenB, I'm not sure this would that much work, as the underlying components/layers start to have meaningful support for this scenario. However, I wouldn't want to be in your testing team. Nevertheless, it would be a diferenciating feature in the current NAS market.
You could come up with a possible path, and always launch it in the "use it at your own risk" spirit we have seen many times coming from Netgear (I'm a legacy user running OS6, I know the drill :-) ).
- StephenBDec 06, 2015Guru - Experienced User
Equinox1 wrote:
...However, I wouldn't want to be in your testing team. Nevertheless, it would be a diferenciating feature in the current NAS market.
I don't work for Netgear, but I wouldn't want to be on the testing team either. There is one common case, where it is simple. That's when new users insert their second disk, and are shocked that they don't get more space. Downgrading RAID-1 back to jbod would allow an easy recovery.
This request is already posted on the ideas exchange, if you are interested in it you could vote for it: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/Switching-disc-configuration-to-user-FEWER-drives-or-FEWER-but/idi-p/988384
It's worth looking at all of those ideas, and voting for all the ones you think you'd use.
- IcyKDec 06, 2015Tutor
I have succesfully 'downgraded' a RAID 6 volume on OS 6.3.5 to RAID 5, once (in order to use one of the disks in another system).
As far as my very limited knowledge goes, hou have to disable xraid first (at least I did). When the RAID 6 volume is in flexraid mode, I could change stuff via the command line as long as the volume size didn't change. (mdadm RAID 6 to mdadm RAID 5 keeps the same BTRFS volume size).
After being done, change back to xraid and a new disk will expand the volume (confirmed).
Of course, ymmv and no guarantees whatoever.
- mdgm-ntgrDec 06, 2015NETGEAR Employee Retired
If you wanted to reduce the volume capacity, that is where there would certainly be much higher risk. As you'd be relying on a number of things working well and if just one of them doesn't then there could be big issues.
We know backups are important, but there would be users who would not update their backup (if they even have one) before doing such an operation even if we provide a number of warnings to do so.
- StephenBDec 07, 2015Guru - Experienced User
A middle ground could be a documented "at your own risk" ssh procedure.
Also, even if volume reduction can't be done, downgrading raid redundancy (raid1->jbod, raid 6->raid 5) would give users more options when their NAS runs out of capacity.
- Equinox1Dec 07, 2015Guide
I agree.
The 'key' here is that the most common scenario is not shrinking the capacity 'per se' but reducing the number of units it relies on.
