eric_wan
Apr 13, 2017Aspirant
How to set permissions for sub folders and files
Hi I have a question about how to set the permission for subfolder? I don't find the settings of the permission of subfolder, the authentication type of my NAS is Active Directory. for ex...
- Apr 14, 2017
This is the correct way to set permissions if the NAS is joined to AD: https://kb.netgear.com/7066/ReadyNAS-OS-6-Setting-Active-Directory-folder-permissions
Apr 14, 2017Guru - Experienced User
The simplest way is to flatten the structure into different shares.
You can also access the share via windows, and right-click on the folders. That will let you set the file permissions via windows.
- jak0lantashApr 14, 2017Mentor
- eric_wanApr 16, 2017Aspirant
I have set permission for the subfolders. Thanks for your kindly reply:smileyhappy:
