bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
mdgm-ntgr
Feb 29, 2012NETGEAR Employee Retired
You need to create the file wihout the .txt extension. Do a command (has Apple symbol on it) + I (i.e. Get Info) of the file and rename it to not have the .txt extension. See if that works.
