bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
majayjay
Aug 13, 2012Aspirant
FYI - Regarding my error "The operation could not be completed. (OSStatus error 2.)" I ended up deleting both users from the ReadyNAS NV+, deleted the keychain passwords for each user account on the macs, then followed the steps outlined above again. It worked correctly after that.
I'm not sure why it didn't work properly the first time... The initial time I tried it, i renamed the user accounts from all lowercase to mixed case & of course, used mixed case in the system files I put in the home folder. When I recreated everything from scratch, I left everything lowercase. I'm not sure if that is the reason it worked the second time?
