bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
mdgm-ntgr
Oct 02, 2012NETGEAR Employee Retired
Might need to check my unit (running latest firmware 5.3.6) later but the quota feature for ordinary users probably isn't in the Dashboard at this time. If you are comfortable with SSH you should be able to set quotas manually though as you can set a quota for the ReadyNAS (Time Machine) user via the Dashboard.
