bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
mdgm-ntgr
Oct 27, 2012NETGEAR Employee Retired
What version of RAIDiator are you running?
How many Macs are you backing up simultaneously?
Are your Macs connected to your network via ethernet or wireless?
Do also remember that full backups take quite some time. After that the hourly backups should be relatively quick.
