bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
Alligator69
Oct 27, 2012Aspirant
Did it, worked perfectly! I just got an error on one of the macs, I believe because the system can only backup one system at a time, will check otherwise if there's something wrong in the config.
Just to understand better: where's the old backup gone? Is it still somewhere or has it been deleted?
Thank you !
Thank you !
