bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
Singularity
Jan 26, 2013Tutor
Unfortunately the Time Machine backup procedure for the ReadyNAS is unreliable. I used it to backup 3 Mac's and after a short time started to have error messages. I then reinstalled the application and set up the backup procedures again only to run into the same problem a short time afterwards.
A great solution but needs a bit of tweaking.
