bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
Grif1
Apr 03, 2013Aspirant
Hi Folks, pulling hair out!
MacOSX 10.8.3
ReadyNAS NV+
Firmware 4.1.10
Raidar 4.3.4
Standard TM setup worked fine but I needed to add ability to TM to a user or share so followed above instructions.
Couple of points to note: I had ReadyNAS set to 'Share' in Security Mode (and I added shares there previously) so I switched it to 'User' mode.
It won't let me add same user as I added as a share so I added another user... fine.
I then created the two txt files
.AppleVolumes with "/c/home/Mark ReadyNAS cnidscheme:dbd allow:Mark options:tm"
and .com.apple.timemachine.supported as a blank
I left 'Enable Time Machine Support' in the Backup menu set to on (or TM wont see the ReadyNAS at all.)
I select "ReadyNAS" in TM list and log in a the user i set able. It gives me an Error 2.
Any help appreciated!
MacOSX 10.8.3
ReadyNAS NV+
Firmware 4.1.10
Raidar 4.3.4
