bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
RhysAndrews
Sep 09, 2013Aspirant
Hey all,
I built an AppleScript app that automatically puts the files into a share that you have created. I used it as I needed to create the files for multiple staff members.
Firstly, you need to create all the users in ReadyNAS FrontView.
Then, open this app and simply enter the username. Once it closes, open it again and move onto the next user.
You need Applescript editor to build an app out of the code.
Make sure you change <adminPassword> and <readynasIP> to the correct values.
Hope this is useful to some of you.
--READYNAS TIME MACHINE PREPARER
--AUTHOR: RHYS ANDREWS
--VERSION: 1.0
--Ask for username
repeat
set username to display dialog "Enter ReadyNAS Username" with title "ReadyNAS Time Machine Preparer" with icon caution default answer "" buttons {"Continue", "Quit"} default button {"Continue"}
set user to text returned of username
set bypass to button returned of username
if user is not "" and bypass is "Continue" then
exit repeat
end if
if bypass is "Quit" then
error number -128
end if
end repeat
tell application "Finder"
delay 0.3
try
-- Mount volume for logging
mount volume "afp://admin:<adminPassword>@<readynasIP>/homes"
on error
display dialog "Login Failed."
error number -128
end try
end tell
delay 2
set AVtext to {"/c/home/" & user & " ReadyNAS cnidscheme:dbd allow:" & user & " options:tm "}
do shell script "echo " & AVtext & " > '/Volumes/homes/" & user & "/.AppleVolumes'"
do shell script "echo > '/Volumes/homes/" & user & "/.com.apple.timemachined.supported'"
