bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
jugalbandi
Jan 24, 2014Aspirant
Does the method posted by bct still work with Mountain Lion. I set up multiple user accounts and added the two files as indicated in only one account. Then tried to connect via time machine preference pane but the time machine volume is not listed. i am not able to add a disk …the option is not available. Do I have to uncheck my regular timemachine volume from frontview?
Also once the two files are added, I no longer can log into that share on afp.
thanks.
jai
thanks.
jai
