bct
Jan 03, 2012Tutor
How-to: Setup multi-Mac backup shares with quotas. Easy.
Over the last couple years, I've been backing up each of my Macs to the default ReadyNAS Time Machine share. It's been OK, aside from having to hack my sparse bundles to stop them from increasing in s...
jugalbandi
Jun 29, 2015Aspirant
I have been using this setup to backup multiple machines for about a year and a half. Works flawlessly.
Yesterday I had a strange problem. About 60 of my 130 applications just simply vanished. The machine seemed to otherwise work fine.
I wanted to do restore from an earlier time machine backup. But when I tried to boot with Cmd+R and choose Restore from Time machine the volumes did not show up.
Before I used this technique I used to use ReadyNAS volume from FrontView for 2-3 years. I no longer use this but this volume is still there with no sparsebundles. This volume shows up.
So is there a setting that I need to have, that shows these volumes on a Cmd+R boot.
All machines, NAS are on the same local network.
