KillerBob
Jul 04, 2012Aspirant
How to "sync" between to NASes
Hi, I have a Pro Pioneer and an Ultra 2, with the Ultra being backup to the Pro. I have setup Rsync jobs on the Ultra pulling data from the Pro every night. How do I go about getting the two in ...
Jul 05, 2012Guru - Experienced User
There is a "Remove deleted files on source" checkbox on step 1 of the frontview backup, which will remove any files on the backup destination that are not on the source.
Normally I leave it unchecked, but every now and then I check it. (not removing deleted files gives me more time to recover accidental deletions - though as you say over time it creates confusion and clutter).
