Mapkwi
Mar 21, 2014Aspirant
Huge mistake-almost 3Tb lost!!
HELP ! I just purchased a RN104 and added two blank 3Tb Red HDD and let the NAS read and configure them. Then I read that after the first two drives, all other ones are just data. So unwittingly I...
mdgm-ntgr
Mar 21, 2014NETGEAR Employee Retired
Thats talking about backing up the data on the NAS already. You can add additional disks without needing to do a backup of the data already on your data volume (though it is advisable to maintain a good backup as things can go wrong with RAID).
With say a RAID-1 volume if you want a larger volume you have to delete your volume (wipes all data) and create a new one. With X-RAID you can add a disk, it will be wiped and added to the array and your volume will expand automatically.
