Mikelm31
Aug 20, 2017Aspirant
Wifi booster for Huges net Satellite
Will this work with. Hughes net Gen 5
- Does the Orbi have phone hook up . I have Gen 5 with phone all Hughes . It's cheap gear . Signal isn't good away from router . It's ok but would like to cover 2000 sq ft
the orbi system will work with anything that doesnt need a modem , in cases where a modem is needed it need to be ether bridged or the orbi system ran in ap mode
- Mikelm31AspirantDoes the Orbi have phone hook up . I have Gen 5 with phone all Hughes . It's cheap gear . Signal isn't good away from router . It's ok but would like to cover 2000 sq ft
no the orbi hooks up to an ethernet port on your upstream modem in your case the huges modem , the huges would still work as normal and you would just disable its wifi then connect the orbi system and run it in ap mode
