greasyrainbow
Apr 04, 2019Aspirant
I accidentally removed Apache from my ReadyNAS and no longer have an admin page.
Like the title says, I was playing around trying to get OwnCloud working and without thinking did an apt-get purge and apt-get autoremove to Apache2 and related software. I was able to reinstall Apac...
Apr 05, 2019Guru - Experienced User
Sandshark wrote:
An OS Re-install does not harm your data. See this thread: OS-Re-install-via-SSH.
It is worth a try, but it doesn't reinstall everything. You still might end up with no web ui, and/or a damaged configuration.
FWIW, I think there's more stuff missing than /var/www. All I see in there is one file (index.html) that you could easily recreate. Note it is owned by guest (which is a bit odd).
root@NAS:/var/www# ls -als
total 4
0 drwxr-xr-x 1 root root 20 Jan 27 06:16 .
0 drwxr-xr-x 1 root root 146 Jan 27 06:17 ..
4 -rw-r--r-- 1 115 guest 53 Oct 9 15:53 index.html root@NAS:/var/www# cat index.html <meta http-equiv="refresh" content="0; url=/admin/">
greasyrainbow
Apr 05, 2019Aspirant
You're right, with Apache2 installed again I only see /var/www/index.html with guest permissions too. Can you look in your /etc/apache2/sites-available/ and sites-enabled/ for me? I have a feeling the ReadyCloud UI is somewhere in there.
- StephenBApr 05, 2019Guru - Experienced User
root@NAS:/etc/apache2/sites-enabled# ls -als total 12 0 drwxr-xr-x 1 admin admin 72 Mar 8 19:44 . 0 drwxr-xr-x 1 root root 240 Jan 27 06:16 .. 4 lrwxrwxrwx 1 root root 36 Mar 8 19:44 000-fv-http -> /etc/apache2/sites-available/fv-http 4 lrwxrwxrwx 1 root root 27 Jan 27 06:16 000-fv-https -> ../sites-available/fv-https 4 -rw-r--r-- 1 admin admin 451 Mar 8 19:44 001-fv-https2
root@NAS:/etc/apache2/sites-enabled# cat 001-fv-https2
<IfModule mod_ssl.c>
NameVirtualHost *:50020
Listen 50020
<VirtualHost _default_:50020>
Include "/etc/frontview/apache/ssl.conf"
Include "/etc/frontview/apache/defaults.conf"
Include "/etc/frontview/apache/http-share-redirect.conf"
Include "/etc/frontview/apache/fv-admin.conf"
Include "/etc/frontview/apache/Shares.conf"
Include "/etc/frontview/apache/apps-https.conf"
Include "/etc/frontview/apache/READYDROP.conf"
</VirtualHost>
</IfModule>
root@NAS:/etc/apache2/sites-enabled#root@NAS:/etc/apache2/sites-available# ls -als total 24 0 drwxr-xr-x 1 admin admin 92 Jan 27 06:16 . 0 drwxr-xr-x 1 root root 240 Jan 27 06:16 .. 4 -rw-r--r-- 1 root root 692 Aug 2 2012 default 8 -rw-r--r-- 1 root root 7251 Aug 2 2012 default-ssl 4 -rw-r--r-- 1 admin admin 379 Oct 9 15:53 fv-http 4 -rw-r--r-- 1 admin admin 374 Oct 9 15:53 fv-http-admin 4 -rw-r--r-- 1 admin admin 412 Oct 9 15:53 fv-https
root@NAS:/etc/apache2/sites-available# cat default <VirtualHost *:80> ServerAdmin webmaster@localhost DocumentRoot /var/www <Directory /> Options FollowSymLinks AllowOverride None </Directory> <Directory /var/www/> Options Indexes FollowSymLinks MultiViews AllowOverride None Order allow,deny allow from all </Directory> ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/ <Directory "/usr/lib/cgi-bin"> AllowOverride None Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch Order allow,deny Allow from all </Directory> ErrorLog ${APACHE_LOG_DIR}/error.log # Possible values include: debug, info, notice, warn, error, crit, # alert, emerg. LogLevel warn CustomLog ${APACHE_LOG_DIR}/access.log combined </VirtualHost> root@NAS:/etc/apache2/sites-available#root@NAS:/etc/apache2/sites-available# cat default-ssl <IfModule mod_ssl.c> <VirtualHost _default_:443> ServerAdmin webmaster@localhost DocumentRoot /var/www <Directory /> Options FollowSymLinks AllowOverride None </Directory> <Directory /var/www/> Options Indexes FollowSymLinks MultiViews AllowOverride None Order allow,deny allow from all </Directory> ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/ <Directory "/usr/lib/cgi-bin"> AllowOverride None Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch Order allow,deny Allow from all </Directory> ErrorLog ${APACHE_LOG_DIR}/error.log # Possible values include: debug, info, notice, warn, error, crit, # alert, emerg. LogLevel warn CustomLog ${APACHE_LOG_DIR}/ssl_access.log combined # SSL Engine Switch: # Enable/Disable SSL for this virtual host. SSLEngine on # A self-signed (snakeoil) certificate can be created by installing # the ssl-cert package. See # /usr/share/doc/apache2.2-common/README.Debian.gz for more info. # If both key and certificate are stored in the same file, only the # SSLCertificateFile directive is needed. SSLCertificateFile /etc/ssl/certs/ssl-cert-snakeoil.pem SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key # Server Certificate Chain: # Point SSLCertificateChainFile at a file containing the # concatenation of PEM encoded CA certificates which form the # certificate chain for the server certificate. Alternatively # the referenced file can be the same as SSLCertificateFile # when the CA certificates are directly appended to the server # certificate for convinience. #SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt # Certificate Authority (CA): # Set the CA certificate verification path where to find CA # certificates for client authentication or alternatively one # huge file containing all of them (file must be PEM encoded) # Note: Inside SSLCACertificatePath you need hash symlinks # to point to the certificate files. Use the provided # Makefile to update the hash symlinks after changes. #SSLCACertificatePath /etc/ssl/certs/ #SSLCACertificateFile /etc/apache2/ssl.crt/ca-bundle.crt # Certificate Revocation Lists (CRL): # Set the CA revocation path where to find CA CRLs for client # authentication or alternatively one huge file containing all # of them (file must be PEM encoded) # Note: Inside SSLCARevocationPath you need hash symlinks # to point to the certificate files. Use the provided # Makefile to update the hash symlinks after changes. #SSLCARevocationPath /etc/apache2/ssl.crl/ #SSLCARevocationFile /etc/apache2/ssl.crl/ca-bundle.crl # Client Authentication (Type): # Client certificate verification type and depth. Types are # none, optional, require and optional_no_ca. Depth is a # number which specifies how deeply to verify the certificate # issuer chain before deciding the certificate is not valid. #SSLVerifyClient require #SSLVerifyDepth 10 # Access Control: # With SSLRequire you can do per-directory access control based # on arbitrary complex boolean expressions containing server # variable checks and other lookup directives. The syntax is a # mixture between C and Perl. See the mod_ssl documentation # for more details. #<Location /> #SSLRequire ( %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \ # and %{SSL_CLIENT_S_DN_O} eq "Snake Oil, Ltd." \ # and %{SSL_CLIENT_S_DN_OU} in {"Staff", "CA", "Dev"} \ # and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \ # and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20 ) \ # or %{REMOTE_ADDR} =~ m/^192\.76\.162\.[0-9]+$/ #</Location> # SSL Engine Options: # Set various options for the SSL engine. # o FakeBasicAuth: # Translate the client X.509 into a Basic Authorisation. This means that # the standard Auth/DBMAuth methods can be used for access control. The # user name is the `one line' version of the client's X.509 certificate. # Note that no password is obtained from the user. Every entry in the user # file needs this password: `xxj31ZMTZzkVA'. # o ExportCertData: # This exports two additional environment variables: SSL_CLIENT_CERT and # SSL_SERVER_CERT. These contain the PEM-encoded certificates of the # server (always existing) and the client (only existing when client # authentication is used). This can be used to import the certificates # into CGI scripts. # o StdEnvVars: # This exports the standard SSL/TLS related `SSL_*' environment variables. # Per default this exportation is switched off for performance reasons, # because the extraction step is an expensive operation and is usually # useless for serving static content. So one usually enables the # exportation for CGI and SSI requests only. # o StrictRequire: # This denies access when "SSLRequireSSL" or "SSLRequire" applied even # under a "Satisfy any" situation, i.e. when it applies access is denied # and no other module can change it. # o OptRenegotiate: # This enables optimized SSL connection renegotiation handling when SSL # directives are used in per-directory context. #SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire <FilesMatch "\.(cgi|shtml|phtml|php)$"> SSLOptions +StdEnvVars </FilesMatch> <Directory /usr/lib/cgi-bin> SSLOptions +StdEnvVars </Directory> # SSL Protocol Adjustments: # The safe and default but still SSL/TLS standard compliant shutdown # approach is that mod_ssl sends the close notify alert but doesn't wait for # the close notify alert from client. When you need a different shutdown # approach you can use one of the following variables: # o ssl-unclean-shutdown: # This forces an unclean shutdown when the connection is closed, i.e. no # SSL close notify alert is send or allowed to received. This violates # the SSL/TLS standard but is needed for some brain-dead browsers. Use # this when you receive I/O errors because of the standard approach where # mod_ssl sends the close notify alert. # o ssl-accurate-shutdown: # This forces an accurate shutdown when the connection is closed, i.e. a # SSL close notify alert is send and mod_ssl waits for the close notify # alert of the client. This is 100% SSL/TLS standard compliant, but in # practice often causes hanging connections with brain-dead browsers. Use # this only for browsers where you know that their SSL implementation # works correctly. # Notice: Most problems of broken clients are also related to the HTTP # keep-alive facility, so you usually additionally want to disable # keep-alive for those clients, too. Use variable "nokeepalive" for this. # Similarly, one has to force some clients to use HTTP/1.0 to workaround # their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and # "force-response-1.0" for this. BrowserMatch "MSIE [2-6]" \ nokeepalive ssl-unclean-shutdown \ downgrade-1.0 force-response-1.0 # MSIE 7 and newer should be able to use keepalive BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown </VirtualHost> </IfModule> root@NAS:/etc/apache2/sites-available#root@NAS:/etc/apache2/sites-available# cat fv-http <VirtualHost *:80> Include "/etc/frontview/apache/defaults.conf" Include "/etc/frontview/apache/http-share-redirect.conf" Include "/etc/frontview/apache/http-redirect.conf" Include "/etc/frontview/apache/Shares.conf" Include "/etc/frontview/apache/apps-https.conf" Include "/etc/frontview/apache/READYDROP.conf" Include "/etc/frontview/apache/lan-try.conf" </VirtualHost> root@NAS:/etc/apache2/sites-available#root@NAS:/etc/apache2/sites-available# cat fv-http-admin <VirtualHost *:80> Include "/etc/frontview/apache/defaults.conf" Include "/etc/frontview/apache/http-share-redirect.conf" Include "/etc/frontview/apache/fv-admin.conf" Include "/etc/frontview/apache/Shares.conf" Include "/etc/frontview/apache/apps-https.conf" Include "/etc/frontview/apache/READYDROP.conf" Include "/etc/frontview/apache/lan-try.conf" </VirtualHost> root@NAS:/etc/apache2/sites-available#root@NAS:/etc/apache2/sites-available# cat fv-https <IfModule mod_ssl.c> <VirtualHost _default_:443> Include "/etc/frontview/apache/ssl.conf" Include "/etc/frontview/apache/defaults.conf" Include "/etc/frontview/apache/http-share-redirect.conf" Include "/etc/frontview/apache/fv-admin.conf" Include "/etc/frontview/apache/Shares.conf" Include "/etc/frontview/apache/apps-https.conf" Include "/etc/frontview/apache/READYDROP.conf" </VirtualHost> </IfModule> root@NAS:/etc/apache2/sites-available#- greasyrainbowApr 05, 2019Aspirant
The sites-enabled was it. Luckily, I just ran the "touch /.os_update" command and rebooted. It restored the apache2 conf and I can access my admin page again.
