greasyrainbow
Apr 04, 2019Aspirant
I accidentally removed Apache from my ReadyNAS and no longer have an admin page.
Like the title says, I was playing around trying to get OwnCloud working and without thinking did an apt-get purge and apt-get autoremove to Apache2 and related software. I was able to reinstall Apac...
greasyrainbow
Apr 05, 2019Aspirant
You're right, with Apache2 installed again I only see /var/www/index.html with guest permissions too. Can you look in your /etc/apache2/sites-available/ and sites-enabled/ for me? I have a feeling the ReadyCloud UI is somewhere in there.
Apr 05, 2019Guru - Experienced User
root@NAS:/etc/apache2/sites-enabled# ls -als total 12 0 drwxr-xr-x 1 admin admin 72 Mar 8 19:44 . 0 drwxr-xr-x 1 root root 240 Jan 27 06:16 .. 4 lrwxrwxrwx 1 root root 36 Mar 8 19:44 000-fv-http -> /etc/apache2/sites-available/fv-http 4 lrwxrwxrwx 1 root root 27 Jan 27 06:16 000-fv-https -> ../sites-available/fv-https 4 -rw-r--r-- 1 admin admin 451 Mar 8 19:44 001-fv-https2
root@NAS:/etc/apache2/sites-enabled# cat 001-fv-https2
<IfModule mod_ssl.c>
NameVirtualHost *:50020
Listen 50020
<VirtualHost _default_:50020>
Include "/etc/frontview/apache/ssl.conf"
Include "/etc/frontview/apache/defaults.conf"
Include "/etc/frontview/apache/http-share-redirect.conf"
Include "/etc/frontview/apache/fv-admin.conf"
Include "/etc/frontview/apache/Shares.conf"
Include "/etc/frontview/apache/apps-https.conf"
Include "/etc/frontview/apache/READYDROP.conf"
</VirtualHost>
</IfModule>
root@NAS:/etc/apache2/sites-available# ls -als total 24 0 drwxr-xr-x 1 admin admin 92 Jan 27 06:16 . 0 drwxr-xr-x 1 root root 240 Jan 27 06:16 .. 4 -rw-r--r-- 1 root root 692 Aug 2 2012 default 8 -rw-r--r-- 1 root root 7251 Aug 2 2012 default-ssl 4 -rw-r--r-- 1 admin admin 379 Oct 9 15:53 fv-http 4 -rw-r--r-- 1 admin admin 374 Oct 9 15:53 fv-http-admin 4 -rw-r--r-- 1 admin admin 412 Oct 9 15:53 fv-https
root@NAS:/etc/apache2/sites-available# cat default
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
root@NAS:/etc/apache2/sites-available# cat default-ssl
<VirtualHost _default_:443>
<Directory />
AllowOverride None
</Directory>
AllowOverride None
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/ssl_access.log combined
# SSL Engine Switch:
# Enable/Disable SSL for this virtual host.
SSLEngine on
# A self-signed (snakeoil) certificate can be created by installing
# the ssl-cert package. See
# /usr/share/doc/apache2.2-common/README.Debian.gz for more info.
# If both key and certificate are stored in the same file, only the
# SSLCertificateFile directive is needed.
SSLCertificateFile /etc/ssl/certs/ssl-cert-snakeoil.pem
SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key
# Server Certificate Chain:
# Point SSLCertificateChainFile at a file containing the
# concatenation of PEM encoded CA certificates which form the
# certificate chain for the server certificate. Alternatively
# the referenced file can be the same as SSLCertificateFile
# when the CA certificates are directly appended to the server
# certificate for convinience.
#SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt
# Certificate Authority (CA):
# Set the CA certificate verification path where to find CA
# certificates for client authentication or alternatively one
# huge file containing all of them (file must be PEM encoded)
# Note: Inside SSLCACertificatePath you need hash symlinks
# to point to the certificate files. Use the provided
# Makefile to update the hash symlinks after changes.
#SSLCACertificatePath /etc/ssl/certs/
#SSLCACertificateFile /etc/apache2/ssl.crt/ca-bundle.crt
# Certificate Revocation Lists (CRL):
# Set the CA revocation path where to find CA CRLs for client
# authentication or alternatively one huge file containing all
# of them (file must be PEM encoded)
# Note: Inside SSLCARevocationPath you need hash symlinks
#SSLCARevocationPath /etc/apache2/ssl.crl/
#SSLCARevocationFile /etc/apache2/ssl.crl/ca-bundle.crl
# Client Authentication (Type):
# Client certificate verification type and depth. Types are
# none, optional, require and optional_no_ca. Depth is a
# number which specifies how deeply to verify the certificate
# issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth 10
# Access Control:
# With SSLRequire you can do per-directory access control based
# on arbitrary complex boolean expressions containing server
# variable checks and other lookup directives. The syntax is a
# mixture between C and Perl. See the mod_ssl documentation
# for more details.
#<Location />
#SSLRequire ( %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \
# and %{SSL_CLIENT_S_DN_O} eq "Snake Oil, Ltd." \
# and %{SSL_CLIENT_S_DN_OU} in {"Staff", "CA", "Dev"} \
# and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \
# and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20 ) \
# or %{REMOTE_ADDR} =~ m/^192\.76\.162\.[0-9]+$/
#</Location>
# SSL Engine Options:
# Set various options for the SSL engine.
# o FakeBasicAuth:
# Translate the client X.509 into a Basic Authorisation. This means that
# the standard Auth/DBMAuth methods can be used for access control. The
# user name is the `one line' version of the client's X.509 certificate.
# Note that no password is obtained from the user. Every entry in the user
# file needs this password: `xxj31ZMTZzkVA'.
# o ExportCertData:
# This exports two additional environment variables: SSL_CLIENT_CERT and
# SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
# server (always existing) and the client (only existing when client
# authentication is used). This can be used to import the certificates
# into CGI scripts.
# o StdEnvVars:
# This exports the standard SSL/TLS related `SSL_*' environment variables.
# Per default this exportation is switched off for performance reasons,
# because the extraction step is an expensive operation and is usually
# useless for serving static content. So one usually enables the
# exportation for CGI and SSI requests only.
# o StrictRequire:
# This denies access when "SSLRequireSSL" or "SSLRequire" applied even
# under a "Satisfy any" situation, i.e. when it applies access is denied
# and no other module can change it.
# o OptRenegotiate:
# This enables optimized SSL connection renegotiation handling when SSL
# directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
# SSL Protocol Adjustments:
# The safe and default but still SSL/TLS standard compliant shutdown
# approach is that mod_ssl sends the close notify alert but doesn't wait for
# the close notify alert from client. When you need a different shutdown
# approach you can use one of the following variables:
# o ssl-unclean-shutdown:
# This forces an unclean shutdown when the connection is closed, i.e. no
# SSL close notify alert is send or allowed to received. This violates
# the SSL/TLS standard but is needed for some brain-dead browsers. Use
# this when you receive I/O errors because of the standard approach where
# mod_ssl sends the close notify alert.
# o ssl-accurate-shutdown:
# This forces an accurate shutdown when the connection is closed, i.e. a
# SSL close notify alert is send and mod_ssl waits for the close notify
# alert of the client. This is 100% SSL/TLS standard compliant, but in
# practice often causes hanging connections with brain-dead browsers. Use
# this only for browsers where you know that their SSL implementation
# works correctly.
# Notice: Most problems of broken clients are also related to the HTTP
# keep-alive facility, so you usually additionally want to disable
# keep-alive for those clients, too. Use variable "nokeepalive" for this.
# Similarly, one has to force some clients to use HTTP/1.0 to workaround
# their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
# "force-response-1.0" for this.
BrowserMatch "MSIE [2-6]" \
nokeepalive ssl-unclean-shutdown \
downgrade-1.0 force-response-1.0
# MSIE 7 and newer should be able to use keepalive
BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
</VirtualHost>
</IfModule>
root@NAS:/etc/apache2/sites-available# cat fv-http
<VirtualHost *:80>
Include "/etc/frontview/apache/http-redirect.conf"
Include "/etc/frontview/apache/lan-try.conf"
</VirtualHost>
root@NAS:/etc/apache2/sites-available# cat fv-http-admin
<VirtualHost *:80>
</VirtualHost>
root@NAS:/etc/apache2/sites-available# cat fv-https
</VirtualHost>
</IfModule>
root@NAS:/etc/apache2/sites-available#- greasyrainbowApr 05, 2019Aspirant
The sites-enabled was it. Luckily, I just ran the "touch /.os_update" command and rebooted. It restored the apache2 conf and I can access my admin page again.
