RoToWe
Feb 12, 2022Aspirant
I can't reach my administration page on my ReadyNas Duo RND2000 v2
I can't reach my administratrion page and get this error "ERR_SSL_VERSION_OR_CIPHER_MISMATCH". It happend recently and I guess it was after I got a new version of Microsoft Edge in beginning of Febru...
- Feb 13, 2022
Yes, it is Firefox 94.0.2 and Internet explorer is removed, as I was advised to do by a friend.
But I had a USB drive connected to my Readynas and when I removed it solved my old problem but got a new problem instead. I loged in to my admin page and got "No shares currently accessible".
I will handle this problem when I have solved Qlocker problem with my other NAS.
Thank you very much for your help. Maybe I connect to you later again but for now I am fine.
Feb 13, 2022Guru - Experienced User
RoToWe wrote:
Sorry! It didn't work. In firefox I got "SLL_ERROR_UNSUPPORTED_VERSION".
I have activated TLS 1.0, TLS 1.1 and TLS 1.2. Firefox will only supprt TLS 1.2.
Firefox worked with my own NV+ (a v1 - which runs 4.1.16 firmware).
Was this with FireFox 94.0.2? (you should check the version, just to make sure FireFox didn't update itself before you could disable that).
Is internet explorer installed on your PC?
RoToWe
Feb 13, 2022Aspirant
