alokeprasad's avatar
Nov 30, 2012
If I replace my 1 TB disks w 2 TB disks, will disks defrag?
I plan to replace the two 1 TB disks in my Duo 1 (X-RAID) with two 2 TB disks. One at a time. Hopefully, all will go well and my data will be preserved.
Will this result in the two 2 TB disks getting defragmented (data written more contiguously) and any improved performance?
Aloke
  • Could you elaborate a bit on how to use the app? The documentation is not very clear (to me) on how to compare the checksums over a set of directories.
    Never mind. I figured it out. Create Digest and then Test Digest using the .md5 file created by Create Digest.
    This will take a long time to create checksums and verify for 700 GB of files over the network!! But at least it is a way to do so.
  • Yes it it can take some time but it does give you peace of mind if you really want it.
ProSupport for Business
