JimBimm
Feb 11, 2014Aspirant
iMac Mavericks Connection to ReadyNAS 104 very slow
Hi folks, when accessing the ReadyNAS 104 from my iMac it takes incredibly long until the content of the selected share shows up. When opening a folder it takes again some seconds until I can see t...
AndrewT1
Feb 12, 2014Aspirant
Hi ..
Yes if you updated from 6.1.4 or below to 6.1.5 you need to do a factory default to fix a problem with file system ... Yep you will need to backup and restore all your data ...
Andrew
Andrew
