JimBimm
Feb 11, 2014Aspirant
iMac Mavericks Connection to ReadyNAS 104 very slow
Hi folks, when accessing the ReadyNAS 104 from my iMac it takes incredibly long until the content of the selected share shows up. When opening a folder it takes again some seconds until I can see t...
bhelgeson
Mar 01, 2014Aspirant
There is an issue with Mavericks and SMB2 to the SMB shares. Try using cifs:// instead of smb://. You can also switch to using smb1 as default by entering this in a terminal window.
echo "[default]" >> ~/Library/Preferences/nsmb.conf; echo "smb_neg=smb1_only" >> ~/Library/Preferences/nsmb.conf
Hope this helps.
Bill
Hope this helps.
Bill
