AGTD
Aug 18, 2012Aspirant
Implausible CPU Temperature readings ReadyNAS Pro4
I have two new ReadyNAS Pro4s, both on Radiator 4.2.21. Both contain 4x 3TB drives. I will call them RN03 and RN04. Both seem to be working without issue, however the CPU temperatures seem to be regi...
Marto731
Aug 19, 2012Aspirant
To ADGT,
Can you contact Tech support in your country. If in UK, can you mail logs to
( level2support *AT* netgear.com). If the 15 degree value is constant, then we are looking at a
hardware issue with chassis.
I don't think there is a software fix, in this instance.
Regards, Marto,
UK L2 Tech support
Regards, Marto,
UK L2 Tech support
