AGTD
Aug 18, 2012Aspirant
Implausible CPU Temperature readings ReadyNAS Pro4
I have two new ReadyNAS Pro4s, both on Radiator 4.2.21. Both contain 4x 3TB drives. I will call them RN03 and RN04. Both seem to be working without issue, however the CPU temperatures seem to be regi...
AGTD
Aug 20, 2012Aspirant
Marto,
No the 15C is not constant. Sometimes it drops down to 6C, and I have seen it go up to 30C if the NAS is under load and the ambient temperature is very high. (At the same time the SYS temperature went up to around 40-45C and the disks went up to 45-47C.).
Does the CPU temperature control the fan speed? It appears that the Disk temperature has a more direct impact on the fan speed.
