stigpepper's avatar
Mar 10, 2018
Inactive volumes - data not available
Hi,   My readynas could not be found on the network so I hard rebooted the box.  After rebooting my volumes are unavailable and I'm receiving the error messages below: -   Volume data   RAID Leve...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Mar 13, 2018
    Have you tried booting to volume read-only mode? If your volume mounts in that the next step would be to make sure you have an up to date backup.
    Are quotas enabled on your data volume (note quotas are used for showing space consumed by individual shares and snapshots, so even if you haven't set a quota on a share, quotas may still be enabled on your data volume)? If so, it's possible an OS Re-install may help as that would disable quotas on the data volume.
ProSupport for Business
