ramram
Feb 13, 2017Aspirant
Inactive volumes!
Dear all Please help my drive has turned like this...this drive is full of DATA!!!! :((
ramram
These are the last entries in the log...
| Mon Feb 13 2017 12:23:32 |
| System: Antivirus scanner definition file was updated to 57.23054. |
| Mon Feb 13 2017 12:23:00 |
| System: ReadyNASOS background service started. |
| Mon Feb 13 2017 12:22:58 |
| System: ReadyNASOS service or process was restarted. |
| Sun Feb 12 2017 11:55:11 |
| System: Antivirus scanner definition file was updated to 57.23048. |
| Sat Feb 11 2017 19:07:27 |
| Volume: Less than 20% of volume data's capacity is free. Performance on volume data will degrade if additional capacity is consumed. NETGEAR recommends that you add capacity to avoid performance degradation. |
| Sat Feb 11 2017 11:52:28 |
| System: Antivirus scanner definition file was updated to 57.23042. |
| Sat Feb 11 2017 7:27:15 |
| Volume: Less than 30% of volume data's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection snapshots will be deleted when volume free space is less than 5%. |
| Fri Feb 10 2017 11:54:53 |
| System: Antivirus scanner definition file was updated to 57.23036. |
| Thu Feb 9 2017 11:48:08 |
| System: Antivirus scanner definition file was updated to 57.23030. |
| Wed Feb 8 2017 11:49:09 |
| System: Antivirus scanner definition file was updated to 57.23024. |
| Tue Feb 7 2017 11:46:23 |
| System: Antivirus scanner definition file was updated to 57.23018. |
| Mon Feb 6 2017 11:44:53 |
| System: Antivirus scanner definition file was updated to 57.23012. |
| Sun Feb 5 2017 11:40:37 |
| System: Antivirus scanner definition file was updated to 57.23006. |
| Sat Feb 4 2017 17:27:15 |
| Sat Feb 4 2017 11:42:41 |
| System: Antivirus scanner definition file was updated to 57.23000. |
| Sat Feb 4 2017 7:07:03 |
| Fri Feb 3 2017 13:13:28 |
| System: Antivirus scanner definition file was updated to 57.22994. |
| Thu Feb 2 2017 11:34:08 |
| System: Antivirus scanner definition file was updated to 57.22988. |
| Wed Feb 1 2017 11:32:09 |
System: Antivirus scanner definition file was updated to 57.22982.
mdgm-ntgr
Feb 13, 2017NETGEAR Employee Retired
So you don't have a backup?
Sounds like you should contact support though there would be some costs involved with looking into this.
