forestpct
Sep 24, 2011Guide
Increase disk capacity on ReadyNa Duo
Hi. I have a ReadyNas Duo at Radiator 1.4.8 with 2x750GB disks configured as X-RAID. Can anyone confirm what the largest disk size I can upgrade to is and if I upgrade simply by replacing one existi...
TeknoJnky
Sep 24, 2011Hero
you mean 4.1.8 ?
the largest disk size the sparc devices (duo/nv+/older) will support is 2tb
yes, replace each disk one at a time (wait for resync/redundant), after the last disk syncs, the system should expand automatically (the you can watch the size on the frontview > volumes page).
Sometimes a reboot or 2 may be necessary, after the last resync.
also, it should be noted that if you use 4k sector drives (aka advanced format), you probably should perform a backup, factory reset, then restore data, for optimal performance.
