modeef
Oct 14, 2013Aspirant
Incremental backups onto 2 USB drives?
Hi, just a quick question about multiple backups: I currently backup my ReadyNas Ultra 2+ onto an external USB drive, kept off-site. I do a backup every couple of weeks via the front button & USB...
Oct 15, 2013Guru - Experienced User
You should be able to do incrementals with no problem. rsync will compare the contents of the USB backup with the share.
Though I do suggest doing full backups occasionally - that will flush out any failures on the USB drive. I have sometimes had read-errors when trying to restore old backups...
