cwiebe
Sep 13, 2013Aspirant
Invalid Certificate.
I have a ReadyNas Duo V2 accessed with FF v23 on Win7 x64. When the nas was first installed, it was given an ip address of 192.168.0.157. Standards are devices get addresses below 120 so it was stati...
cwiebe
StephenB, I have tried to coax FF to save the certificate, but it doesn't stick. Same with chrome. The certificate is still signed from the original .157 address, not the current .7 address. Not allowing a change in the ip address is definitely a defect with the Netgear software.
1 We should use https for increased security.
2 We'll create a certificate that becomes useless minutes after installation and not have a simple method to update the certificate.
3 We'll just tell folks to not worry about the invalid certificate, just click through it. (see step 1)
- May 04, 2020Retired_Member
