cwiebe
Sep 13, 2013Aspirant
Invalid Certificate.
I have a ReadyNas Duo V2 accessed with FF v23 on Win7 x64. When the nas was first installed, it was given an ip address of 192.168.0.157. Standards are devices get addresses below 120 so it was stati...
vandermerwe
Sep 13, 2013Master
I think you find the https settings in Configure, System, Services, https.
Once you've done this make sure you clear your browser cache.
You may need an OS reinstall as well if the above doesn't work.
If you access the unit in different ways, what exactly do you mean - even an IP address and a name are only 2 exceptions to add. You should only have to do this all once.
- May 04, 2020Retired_Member
